HELP!
From: First one out of liberty city, burn it to the ground
HELP!
Im hooking up an MSD 6a to my other car, a 72 chevelle, it has non-hei, and an external coil. If i interpreted the directions right.. i hooked up the orange wire to the + on the coil, black wire to the - on the coil, red wire to the ignition switch, white wire to the original power wire to the coil... i also hooked up the other ground and power wires to the battery... no fire. No spark.. how did i hook up that white wire wrong?? how is it supposed to go?
1972 Chevy Chevelle "Malibu"
Hooker Headers, Flowmaster 40 series mufflers, accel 8.8 wires,Edelbrock performer intake Edelbrock Carb, Torque Thrust "D" wheels
Click here for my Malibu information
In Memory of #3 Dale Earnhardt
btw..there were 2 wires going to the +.. we put them together and connected them to the white wire going to the MSD 6a
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Points distributor huh? Did you not have the room to drop in an HEI?
I doubt this will save the day but...
That's from the MSD website for a points-type distributor.
If you have a tach. that's probably your 2nd wire going to the white one on the MSD.
Hope that helps
"Always do sober what you said you'd do drunk. That will teach
you to keep your mouth shut."
[This message has been edited by deadbird (edited October 15, 2001).]
Hope that helps
- my Formula Homepage
- Collision P/Ns & Diagrams (Nearly complete now!)
