Cig. Lighter Woes
Old Sep 19, 2002 | 01:45 PM
91TealRS's Avatar
Cig. Lighter Woes
My cigarette lighter socket works fine...it will run my vacuum cleaner and cd player, but if you stick the actual lighter in it....ZAP. Fuse blows. Actually, with the cd player and vac, if you stick it in far enough it will blow the fuse as well. So obviously the lighter doesn't help since you NEED to push it all the way in. Anyways, I took the thing apart and found a few tiny metal pieces in there, cleaned it out with a wire brush, and still blows the fuse. Any ideas? I know this topic has been addressed numerous times, but the damn thing works...just not completely...
Old Sep 20, 2002 | 12:33 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You can get a replacement cig lighter/sockets at most autopart stores for under or around $5 usually. Save yourself the headaches and fuses and just replace it.
Old Sep 24, 2002 | 04:28 AM
SinthetikIroc's Avatar
Car: Corvette
Engine: 5.7
i took mine out and put a switch to kill my amps power there. i dont smoke or nothing and i dont use any things that plug in there so i tossed it. i decided to do it after i used my last fuse. didnt feel like buying more fuses
Old Oct 10, 2002 | 08:57 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Yeah go pick up a new one. Should only be a few bucks. Gettin rid of it would certainly fix the problem, but sometimes those lighters can come in real handy.
ZZ3Astro
Aug 13, 2019 12:57 AM
Moore89
Aug 24, 2015 07:06 PM
crazynights
Aug 21, 2015 06:53 AM
Bawls
Sep 30, 2001 03:40 AM
Sweet_85_Bird
Nov 14, 2000 07:25 PM
