Ahh , crazy brake lights, this is weird HELP
Old Oct 23, 2001 | 10:51 PM
breathment's Avatar
Ok, my top mount brake lights are not working, so i thought maybe it was the bulbs themselves, so i went to autozone and brought two new ones. well i pulled the cover off and the bulbs looked fine, but i recplaced them anyways. NOPE still didn't work. So i get my digital multimeter and test the voltage. 11.5 volts when brake pedal pressed. 13 volts when car is on BUT,, this is with the bulbs OUT. i put the bulbs back in, tested the voltage, probbing the SAME place, ZERO volts.
it makes no since, so i take out just one bulb, and leave one in. still ZERO volts, i don't get it. when the lights are in, the voltage goes down to zero, take them out, it goes up to 12.
wut is causing this? its so confusing
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
Cleotiz
Jan 6, 2018 08:56 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
