starting problem
Old Oct 23, 2001 | 10:02 AM
quest for 12sec..92RS's Avatar
starting problem
I don't know what the deal is. The battery is good and everything works except the starter at times. Just everyonce in while the car won't start but later on in the day it will. Does anyone have any ideas of what this may be. I think it may be the connection at the starter or some corrosion around the connection. I will check, but I just wondered if anyone else has run into this kind of problem. Later
Old Oct 23, 2001 | 02:35 PM
89 CamaroIROCZ's Avatar
I'd say it's probably Heat Soak. Your starter is probably old and about to go anyway. Atleast mine was. Changed it and that was the end to all worries.
Matt
89 Camaro IROC
350" GM Crate Motor
650 Holley Double Pumper Carb, Crane Energizer Camshaft (278/290 .476/.494), Edelbrock Torker II Intake Manifold, Hedman Headers, Dynomax Catback Exhaust, B&M Holeshot 3000 Lockup Converter(Yeah, its a little big), B&M Stage 2 Shift Kit and plenty more little stuff that has cost me BILLIONS i'm sure.
Stereo: Sony POS Head unit, Sony Explode Amplifier 200x2 RMS, Pioneer 10" subs, Boston Aqustic 6x9 & 4x6's.
MOD's to come: Vortech heads, 1.6 Stamped Rockers, New Head Unit, and some better 10" subs.
Old Oct 23, 2001 | 04:51 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
MADD make a soleniod relocation kit that will forever solve your problem. A new starter will work fine for a while, but the S.O.S. will start again.Get the relocation kit.( I think Summitt carries one, too.)
Carburated 5-speed
Vortec heads,1.6 roller rockers, .480 Crane cam,T-5,355 4-bolt, 3.73 posi,SSM Kit
Old Oct 24, 2001 | 07:26 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
If the problem is happing when the car is cold it is not heat sock. We need more info. Is this only when the car has been running? If so it is probably heat soak. If not, dose the starter crank? If not it may be a VATS problem. Give use a little more detail.
Now I HAVE_A_Z
89 IROC 350 TPI
Old Oct 24, 2001 | 11:45 AM
It usually fails to start in the mornings when it is cold. Sometimes it will do it after the car has been running but has sat for a while. Its really weird. It acts as if the battery is dead but the battery is fully charged. Yet the starter won't engage. But then sometimes it will at like it has no problem and starts right up. Although the starter seems to turn the engine over slowly a lot of the time. I hope that helps. Thanks for the posts guys, if you have any ideas I would love to hear them.
Old Oct 24, 2001 | 03:19 PM
mtccl's Avatar
First cheap thing to check is the battery connections, then the starter to battery wire, then the battery to car ground. Loosen and wire brush the connections. Check your wires closely. Sometimes the end pieces, especially down on the starter get corroded and don't ground giving you the intermittent condition. Next check the solenoid. Cheaper to replace than a new starter.
87 TA, 305 TPI, Custom CAI, ACCEL 8mm wires,ACCEL Super-coil, ACCEL Plugs, JET TPI Airfoil, Cherry Bomb Muffler
"35 yr old helo pilot
with a cool new toy my 17 yr old son wants"
The Phoenix Project..click to see my project car
Trans Am stuff and GIRLS, GIRLS, GIRLS!!!!!
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
