after motor swap, no heat ???
Old Oct 24, 2001 | 11:01 PM
JunkHead84's Avatar
i just finished getting back all my interior lights because they were hacked up, but then i noticed i had no heat when i played with the settings. does a wire run the heat by any chance? if it helps i removed the ac,and theres a brand new heater core. thanx
Old Oct 24, 2001 | 11:10 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Damm bud,, you're just having all kinds of troubles huh ?
There is no wiring that controls water flow to the heater core. The door & heater control valve are all controlled by vacuum.
"Always do sober what you said you'd do drunk. That will teach
you to keep your mouth shut."
E Rod
Aug 28, 2015 05:17 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
st.evel07
Aug 13, 2015 06:15 PM
fonzie85
Aug 13, 2015 11:50 AM
