Speedo help please
Old Oct 24, 2001 | 10:25 PM
CamaroEFI's Avatar
Speedo help please
what are the most common causes of the speedo not working at all on a 140k mile 91' RS 305 (L03)? thanks
Old Oct 25, 2001 | 06:37 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Does the cruise control work (if equipped)? If not, I'd start with checking the VSS & its drive & driven gears at the trans. The VSS connects to the VSS buffer box, which is near the ECM. The VSS buffer sends a 4000 pulse per mile signal to the ECM & the cluster, and a 2000 pulse per mile signal to the cruise control module. Both VSS buffer outputs should toggle between 0 and 5 volts while the car is moving.
Tim
1992 Z28, 305 TPI 5 speed, 12.1 sec @ 114.7 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Nervous2
Oct 8, 2015 10:53 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
