spent an hour working of headlight motors
Old Oct 14, 2001 | 07:58 PM
breathment's Avatar
Took off the whole assembly, not to hard to do, just don't drop the parts down to the air dam or the many other plastic peices that are flat on the bottom. well got the assembly off, got the motor off, tried rotating it without taking the gear out (like they show for the 4th gens.), dind't work, so i tried taking the gear out, couldn't get it out, so i rotated it again. still no luck, I just now read Steves Trans Am page thingy. and im gonna follow that probably tomorrow or next weekend, i have way to many projects ahead of me, the worst part was i took alot of pictures thinking i could make a tech article, now i just have wasted pictures unless i can get it fixed.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
Old Oct 15, 2001 | 11:45 AM
scauffiel's Avatar
Well you could always send me the pix and if they show anything better than the ones I have I can put them on my site as well.
Steve
Old Oct 18, 2001 | 06:56 AM
Smeg's Avatar
Car: 1990 Black TransAm GTA hardtop
Transmission: THM700R4
Axle/Gears: 3.23 w/Alu prop
I followed Steves instructions a few days ago, and thanks to him I have perfect up/down action!
BTW, I couldnt get anything larger than a 9mm ball bearing, but it worked fine.
Smeg
89 GTA 5.7 TPI
Old Oct 22, 2001 | 10:17 AM
mtccl's Avatar
I followed Steves directions (which are excellent) but turned out that someone had already rebuilt my motors. Mine was the modulator on the firewall that was bad. If the motors aren't spinning...it's not your gears.
87 TA, 305 TPI, Custom CAI, ACCEL 8mm wires,ACCEL Super-coil, ACCEL Plugs, JET TPI Airfoil, Cherry Bomb Muffler
"35 yr old helo pilot
with a cool new toy my 17 yr old son wants"
The Phoenix Project..click to see my project car
Trans Am stuff and GIRLS, GIRLS, GIRLS!!!!!
Old Oct 22, 2001 | 10:45 PM
breathment's Avatar
i think they are REALLY bad stripped, they dont go up or down without my help, plus i didn't get the gears off, i couldn't figure out untill i read his thing, ill try it this weekend, if it works ill show the pics.
- David
Old Oct 26, 2001 | 01:15 PM
NavySonarTech's Avatar
I fixed mine by ordering from Rodney Dickmans Fiero web site. They have the same headlight motors as we do. The rebuild kits are really very cheap something 19 dollars for four rebuilds for my cars.The rebuild is easy for the passenger side but the drivers side you cannot take the plastic gear out until you first take the two small screws holding the motor in place
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Andrew6.688
Dec 13, 2015 10:59 AM
BlackphantomZ28
Aug 31, 2015 10:29 AM
TheExaminer
Aug 26, 2015 04:59 PM
