help! blinkers
Old Aug 15, 2001 | 10:42 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
help! blinkers
hey guys i changed my ignition switch in my column a while ago, and i noticed that my blinkers do nothing if you hit the switch, what do i check?
86 Camaro with 88 305 LB9 using 86 carb setup, edelbrock performer manifold, 305 S/R Torquer Heads, Hedman Headers, Crane Compucam 2032 edelbrock cat-back, gutted cat, slp underdrive pulley, mallory ignition, 305 h.o dual snorkel air cleaner, hypertech thermomaster chip,160 degree thermostat, 5-speed, 3.23 posi
95 Beretta Z26, 3100 V6, 4 Speed auto, stock
Old Oct 26, 2001 | 06:01 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
anyone?!?
Old Nov 3, 2001 | 03:16 PM
JoshDT91's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
Well since nobody else is going to help you I might tell you to check your wiring. If you have been having this problem since August, just go have it fixed somewhere.
2.8L V6 173ci
K&N Air Filters
JET Underdrive Pulleys
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Jk_Under
Sep 2, 2015 10:59 PM
bklucas12
Jan 11, 2002 06:44 AM
super83Z
Jun 2, 2001 10:44 AM
Jimmy91RS
Sep 28, 2000 02:16 PM
