Gauge cluster swap-HELP!
Old Nov 4, 2001 | 04:13 AM
up2nogud13's Avatar
My '83 Camaro (4 cyl orig.)now has a 350 w/TH350. It still has the original gauge cluster-85 mph speedo, big gas gauge on the right, and idiot lights between for battery, oil pressure and temp. I have a cluster from a junked '8x with a 115 mph speedo, tach on right w/inset oil pressure gauge, and middle gauges for gas, temp, and volts. Anyone know how to make this swap before I jump in blindly? Any help would be greatly appreciated! Thanks
[This message has been edited by up2nogud13 (edited November 04, 2001).]
Old Nov 4, 2001 | 08:46 PM
305IrocZ28's Avatar
Car: 1990 IROC-Z
Transmission: 700-R4
I'm not too sure about this sort of thing, but I have an idea or two. My first question that I would have is relative to the setup you have- do you have all of the wires and related hookups for the gauges (like the oil pressure, engine temp..etc), since your old cluster DIDNT have those? I would check into that and see if you need to get additional wiring or equipment for the new cluster.
Old Nov 6, 2001 | 10:47 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
AFAIK, you need to replace the idiot light senders with the correct ones for gauges, and then bolt the cluster in. The wiring plugs are identical AFAIK.
If the tach doesn't work, you may have to run a wire for it.
Old Nov 6, 2001 | 02:01 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The schematics for both types of clusters may be found here: http://www.geocities.com/vtcamaro/Wire-Diagrams.html
You will have to run a tach wire from the coil (white wire) to the cluster, in order for the tach to work.
Tim
1992 Z28, 305 TPI 5 speed, 12.1 sec @ 114.7 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
