cluster/guages not working? and when turn on lights it makes a beep..
Old Oct 26, 2001 | 10:02 AM
twiztid's Avatar
All my cluster/guages are not working right, the lights work and everything. When I turn on my lights it makes the beep noise that tells you your lights are still on when you turn your car off? anyone know what the deals is.. also when I stick it in nuetral when I am driving and turn the car off, it still stays on. I turned it off and went to start it and it make the hard start noise like when your car is allready started and you try to start it again. Hopefully it is something simple, I checked the fuses that I knew of. I own a 89 pontiac firebird 350 tpi if anyone needs to know.
Old Oct 26, 2001 | 10:32 AM
twiztid's Avatar
ok, I figured it out, I checked my fuses for the third time and missed it everytime, one time was in half dark, but that was my problem. thanks anyways guys
Old Nov 6, 2001 | 07:54 PM
pico87iroc's Avatar
witch one waas half dark i have the same problem and then some
87 IROC-Z 305tpi
still $h!ten on
rustangs
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Jae992
Aug 27, 2015 09:07 AM
Omega
Aug 10, 2015 12:46 PM
Fronzizzle
Aug 9, 2015 01:15 PM
