No lights!!
Old Nov 8, 2001 | 11:14 AM
85wilrocu's Avatar
No lights!!
Can someone please help! I need to know the reason why i have know lights? Is it the pull out light switch or the steering column? The reason why i say the steering column is all the other lights work except the low & high beams and also the fog lights?
1985 Iroc Modifications:
Ram air,K&N filters,Mas Screens off, fins taken off,52 MM Throttle body,
Corvette servo,B&M Transmission shift kit,
Flowmaster exhaust system
March Performance pulleys
Hypertech super coil.
Fords are Like Tampons, Every PU$$Y Has One!
Old Nov 8, 2001 | 01:30 PM
mtccl's Avatar
You're going to have to give us some more information. What happens when you pull out the ****, etc. Do your turn signals work? First guess is that it is the headlight relay if your Z has one.
87 TA, 305 TPI, Custom CAI, K&N, ACCEL 8mm wires,ACCEL Super-coil, ACCEL Plugs, JET TPI Airfoil, Cherry Bomb Muffler
"35 yr old helo pilot
with a cool new toy my 17 yr old son wants" The Phoenix Project..click to see my project car
Trans Am stuff and GIRLS, GIRLS, GIRLS!!!!!
Old Nov 8, 2001 | 01:47 PM
85wilrocu's Avatar
O.K WHEN I GO TO TURN ON THE LIGHTS ALL THE LIGHTS WORK EXCEPT THE HEADLIGHTS! (FOG LIGHTS, LOW AND HIGH BEAMS)THE ONLY LIGHTS THAT DO WORK ARE BACK LIGHTS, SIDE MARKERS ETC. AND WHEN I WENT TO TURN ON THE HIGH BEAMS TO SEE IF THEY WORK, THERE WAS KNOW CLICKING NOSIE FROM THE HANDLE, SO THATS WHY I THINK ITS THE HIGH BEAM SWITCH!???
SORRY ABOUT THE CAPS
Old Nov 8, 2001 | 02:11 PM
mtccl's Avatar
Does the little "Blue" high beam light come. There is a switch inside the column that acutally controls the lights not the stalk itself. That would keep you lights from working at all though I don't believe.
Old Nov 8, 2001 | 02:13 PM
85wilrocu's Avatar
How do I get to that switch? and where is it located?
Old Nov 8, 2001 | 02:14 PM
85wilrocu's Avatar
Oh yeah, the blue light doesn't come on!
Old Nov 8, 2001 | 02:21 PM
mtccl's Avatar
It is inside the steering column, but I would check the relay first. I have a TA so I'm not familiar with your setup. My headlight relay is near the battery. Check that first. Also, check all your fuses.
Old Nov 11, 2001 | 08:00 PM
Greg Kuhlmann's Avatar
My 87 T/A had a really loose steering wheel.. then the headlights would blink off and on... the highbeams were stuck on... everythig was going wroung w/my lights. I had a new Blinker,high beam etc switch put in.. they are like 20 bucks and everything works good now! so you might want a new switch!
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
