Hatch motor problems, please help
Old Nov 18, 2001 | 05:25 PM
Voodoofighter's Avatar
The hatch motor on my 91 Formula decides on somedays that it dosn't feel like pulling the hatch down...I have "jiggled" all the wires and checked the conections for any obvious problems, but what else could be wrong? Is the motor going bad, or could there be another cause? Thanks in advance.
Old Nov 19, 2001 | 01:44 PM
305IrocZ28's Avatar
Car: 1990 IROC-Z
Transmission: 700-R4
One question, since you apparently have that device as well. Mine doesn't work AT ALL. Is it an automatic thing? I have tried on several occasions to make it work, but I have had no luck. Hmm.
305IrocZ28- Al
1990 Iroc-Z
305 TPI
0-60 in 6.8 (timed)
2.73 Posi (3.42 or 3.73 to come)
Flowmaster exhaust
T-tops
Red w/ black racing stripes
Pioneer headunit, stock speakers, Rockford 10'' punch woofers
Ricers beware...I eat you three meals a day
And the Camaro said to the Civic "Now, I know what you're thinking...in all of that mess, did he have 8 cylinders, or only 6? You just gotta ask yourself one question...do you feel lucky? Well do ya....punk???
Old Nov 19, 2001 | 05:50 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
There is a small switch on the left side right where the loop from hatch contacts the pull-down unit. Press this switch and the unit should power down. If this doesn't cure it, is there power to the unit? Just because the hatch solenoid works doesn't mean the motor is getting power. Last, if it makes noise, but doesn't go up or down, the gear nut is likely shreaded. It's available from the dealer p/n 20160587 for around $5. If you have to disassemble the hatch pull-down unit (to replace the gear nut). You will likely discover the guides are shot. GM doesn't have replacements and would prefer to sell you the entire hatch pull-down assy for around $400. But there is now another choice. I have manufactured new replacement guides and am selling them. E-mail me if you need them. Thanks, Lon.
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Nov 19, 2001 | 10:24 PM
Raptor Pilot's Avatar
Yeah, the motor makes that click sound like it releases, but then there isn't any motor action at all to pull the hatch up or down. So is my problem that nut?
Old Nov 19, 2001 | 11:33 PM
harvtherabbit's Avatar
you can allways do like i did and bypass it by having it welded closed now i have no more stupid hatch moter problems
Old Nov 20, 2001 | 09:51 AM
lonsal's Avatar
If you are NOT hearing the motor run, than replacing the gear nut isn't the solution. You will need to see why the motor isn't working. Check the switch and that the motor has electricity. It sounds as if you will need to take the plastic trunk trim out and investigate it.
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
1nastygta
Aug 8, 2015 07:38 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
