Speedo!
Old Nov 19, 2001 | 12:11 PM
Loki1199's Avatar
Speedo!
Hi all,
I had my 700R4 swapped to a TH350 a while back and I have been driving without a speedo since. Well, it's inspection time and I need to get it to work now. I was told that I need to swap the tail housing off my current tranny to get it to work. Is there any easier way? The tail housing is a tough job, is it not?
Any replys would be greatly appreciated.
Old Nov 21, 2001 | 10:07 PM
un4givin89's Avatar
bttt
Old Nov 21, 2001 | 10:26 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
If you had your 700R4 swapped out for a 350 turbo then the driveshaft was also changed because the TH350 is a shorter tranny than the 700R4... so you're just looking for trouble switching the tail housing. If you had an electric speedo then whoever did your tranny swap should have put the electric VSS from the 700R4 in the tail housing of the TH350 and then the wire that was plugged into the 700R4 just plugs back into it. The VSS IS interchnageable from the 700R4 to the TH350.
Old Nov 22, 2001 | 12:52 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
How do you figure the VSS from a 700 can be put on a 350?
Old Nov 22, 2001 | 01:49 AM
<font face="Verdana, Arial" size="2">Originally posted by Apeiron:
How do you figure the VSS from a 700 can be put on a 350?</font>
Actually... I retract that statement. I just thought about it and realized that when I switched to my TH350, it had an adapter and spacer kit installed to mount the 700R4 tail housing to the TH350 and use my stock driveshaft. My bad.
Old Nov 22, 2001 | 05:40 PM
Loki1199's Avatar
OK.
I logged into the Summit site and found a 16 pulse hall effect sender that is supposed to convert a mechanical sender to electronic - supposed to fit all Autometer speedos. If I pick this up, plug it into my tranny, how do I wire it so I can plug in my stock Speedo? The connections are different. Any help would be great. Thank you all
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Nervous2
Oct 8, 2015 10:53 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
