Relays: help!
Old Sep 29, 2002 | 02:06 PM
DJXero's Avatar
Car: 1992 Camaro Z28
Relays: help!
My starter us having problems, and I think it may be in the relay, but I'm not sure. When I try to start my car, the solenoid engages, I can hear the clicking, but it won't turn over. Most of the time the solenoid won't even engage, and a relay located behind a panel right on the drivers side near the pedals will start buzzing. I thought myrelay had just blown so I bought enother one, but it started doing it again about a week after I put the new relay in. I got a new starter too, but I'm still having problems. Does anyone know what may be the matter?
http://www.napaonline.com/cgi-bin/nc...num.d2w/report
I don't know if the link will work, but on Napa, it's part # AR136.
1991 Camaro RS
305 V8
Old Sep 29, 2002 | 10:36 PM
iroczVinnie's Avatar
Car: 89 IROCZ vert
Engine: 305TPI
RE
Start with the basics first
Have you checked your battery? A clicking relay sugests that there is enough power to power the relay, but not enough to turn the starter,
from this, you said that you have replaced the relay, could the starter be engaged? ie stuck?
Old Oct 10, 2002 | 01:48 AM
86LB9's Avatar
Check your battery cables! They cause a lot of these problems and are cheap to replace. First I'd take a voltmeter and check the voltage at the battery from post to post. Then check the voltage at the starter. If there is a big difference, it's your cables. If not, your solenoid maybe getting worn out. Most auto parts stores will check your starter for free. Definitley worth the time and the price....free!
JamesC
May 9, 2011 08:34 PM
HutchBMX
Jun 15, 2010 12:44 PM
PhLaXuS
Sep 25, 2005 02:13 PM
JamesC
FAQ Board
Jul 16, 2005 03:04 PM
