wich one is the VATS relay? (pic attached)
Old Sep 29, 2002 | 03:10 PM
Psyte's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7L 600cfm carb
Transmission: 700R4 (auto)
well, the subject says it all..... i cant figure out wich one of these two relays is the VATS relay. i need to bypass it so that i can start my car. (im converting from tpi -> carb)
Attached Thumbnails wich one is the VATS relay? (pic attached)-driver-relays.jpg
Old Sep 30, 2002 | 01:09 PM
Tonyrodz's Avatar
Transmission: auto
I think I'm having the same problem w/my car!
Sorry can't help you out--but I'm gonna keep my eye on this one!
BTW--did you check the pas-key module? Also-did you check for wiring coming out of the steering column going to the module?
I've always heard those wires can go bad--somehow!
Old Oct 1, 2002 | 10:32 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
the relay on the bottem left corner is the start enable relay open it up and hold it closed while you start the car.see if that works?
Old Oct 1, 2002 | 07:55 PM
Psyte's Avatar
relay
ok, ill give that a shot, thanx for the info. as for the steering wheel colum, there are so many wires comeing out of that thing that i have no idea where to begin.....
Old Oct 9, 2002 | 09:11 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
You shouldn´t need to bypass the VATS just ´cause you´re switching systems. If you have a problem with the key, you can take it to get a copy made and they´ll read the correct code from your current key and make another one just like it. These chips on keys sometimes get dirty or worn and don´t make a good conection. Try that first! The VATS system is a good thing to have working, it gives your car a little more protection against thiefs.
David
Old Oct 9, 2002 | 10:17 PM
redcamaro83's Avatar
Car: 86 Z28
Axle/Gears: TBD
Re: relay
did it work?
Glowsock
Jul 24, 2025 03:15 PM
Street Lethal
Apr 30, 2019 12:14 PM
stalkier
Dec 6, 2015 11:25 PM
Trickskier
Aug 29, 2015 01:12 PM
Bert87
Aug 23, 2015 03:50 PM
