Underdash harness...
Old Sep 30, 2002 | 09:19 PM
90FirebirdV6's Avatar
is the wiring under the dash a seperate harness from the engine compartment aswell as the tail lights? im thinking of swapping mine out to eliminate any wires issues, cause when i got the car alot of wires were hacked up underneith. Has anyone done this? how long did it take? and was it hard?
Old Oct 1, 2002 | 12:20 PM
Nate1's Avatar
Car: 88 IROC-Z, 71 SS 454 Chevelle
Engine: 305 TPI, 454
Transmission: 5spd, th400
You have to drop the whole dash and disconnect the dash harness from the engine harness. It is connected where the harness goes through the firewall on the drivers side. I would plan on this being a weekend project, though.
The engone harness and the tail light harnesses are connected to the dash harness by plugs. If you take the harness out of the donor car mark all of the connections so as to make it easier to install in your car.
I put a dash harness from a Z28 into a reg. camaro and was not that hard.
scottmoyer
Feb 7, 2019 07:11 PM
StocRoc
Feb 24, 2004 10:47 PM
Randy82WS7
Jun 15, 2003 12:09 AM
jermdm
Nov 23, 2002 08:48 PM
