Ignition Sequence Problem
Old Dec 8, 2001 | 12:43 AM
12sec305's Avatar
heres the deal i put a new intake an carb on the car which meant pullin the distributor but dumb *** me didn't mark it so when i went to put it back in i brought the motor up to tdc on the 1st cyl. not exactly how close cuz i used the dampner to eyeball it with.then took the cap off and check where the rotor was and proceded to put the wires on 18436572 clockwise and when i tried startin the car it ran like **** sounded like it had a cam and backfire through the carb bad when i gave it some gas.need help my beretta threw a rod and i need to get this on the road any info would help thanks
Old Dec 10, 2001 | 01:33 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Put the #1 cyl @ TDC on the compression stroke - both valves are closed - & then point the rotor just before the #1 wire (a bit toward the #2 wire). Cyl #1 is on the drivers side @ the front & 3,5,& 7 are also on the driver's side.
Tim
1992 Z28, 305 TPI 5 speed, 12.0 sec @ 114.8 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
Infested
May 22, 2018 11:56 PM
mddaniel
Sep 8, 2015 05:16 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
