Cyberdyne VSS question
Old Dec 4, 2001 | 08:12 PM
tinybfl's Avatar
Ok where is the double brown wire, this is starting to tick me off. Ok I relized that i had to remove that stupid yellow box and it only took me 3 months to come to that realization even though the directions clearly state that. still no double brown wire. Also I took the grey box off the conector revealing the end of the printed board <i currently have it wired to that with no imediate failure>. But i want to make sure im doing it right so someone please tell me what double brown wire could they be refering to the double brown going into the white male connector?
1986 Iroc Z-28. Primer Grey soon to be dark purple. Upgraded suspension, poly bushings, new black interior &lt;except seats&gt;, cyberdyne guages.
Old Dec 13, 2001 | 02:00 PM
Jza's Avatar
Jza
If you look at the connector inside the car that plugs into the backside of the cluster housing, on the far upper-right pin you'll see that there's actually two brown wires attached to that pin.
I thought you finished that install already? Although I notice this post is from the 4th...
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
GTAman
Aug 27, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
fonzie85
Aug 13, 2015 11:50 AM
mizz0313
Aug 12, 2015 06:45 AM
