have wiring problem... i think
Old Oct 8, 2002 | 07:50 PM
luvrgodd's Avatar
Car: 02 Z06
Engine: LS6
Transmission: MN12
my left front turn lamp is extra bright and doesnt blink when i turn on the blinker, the right one works fine though. i asked someone and he said most likely something is grounded out. has anyone ever had this problem and could you help? if something is grounded out, would there be a good place to start looking? any help would be much appreciated. thankyou
Old Oct 8, 2002 | 08:10 PM
1986redbird's Avatar
check your left rear turn bulbs, if one or more of them is out it will stop them from flashing and could make the front bulb brighter.
Old Oct 15, 2002 | 06:42 AM
aussierob's Avatar
Change the brighter globe. The filament has fused itself making it shorter , this usualy happens with cheap globes. This can happen when you go over a bump etc. You can try this with a globe connected to 12 Volts and then flick it with your finger when its hot and you either break the filiament or it can fuse itself shorter. this usually makes it brighter.
Old Dec 18, 2002 | 01:46 PM
luvrgodd's Avatar
Car: 02 Z06
Engine: LS6
Transmission: MN12
but what would be the problem with the front lamp not working with the blinker???
Old Dec 18, 2002 | 07:17 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
With the lights off, does the turns signal work dimly and/or does the signal indicator in the car work ?
It's not all that difficult to put a dual element bulb in backwards (seems more common to do in the tail lamps for some reason). If the 'signal' element is lighting for your 'park' lamp, you'll never see the signal flash unless the lights are off. That's just a guess though...
Old Dec 19, 2002 | 08:11 AM
luvrgodd's Avatar
Car: 02 Z06
Engine: LS6
Transmission: MN12
with my lights on and headlights up, the light is on but it will not work with the turn signal. also when my lights are off the turn signal still doesnt work. inside the car, when the lights are off nothing out of the ordinary but when i turn the lights on the green left arrow inside the car stays on if im using my left turn signal or not. the left front side blinker thingy the little yellow side light blinks with the blinker but it is opposite the rear turn signal. whats the deally??
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
