Need some experienced help NOW!!
Old Oct 8, 2002 | 09:11 PM
redcamaro83's Avatar
Car: 86 Z28
Axle/Gears: TBD
i am two days from buying a 1990 camaro RS
the column is messed up so the ign key does not work niether does the screw driver method.
i have no prob buying new column
but want to start car prior to buying it
how can i get around the factory alarm (chip in key?) so i can either driveit home or check condition.
if you feel this is sensitive info e-mail me.
jonathan-2fast4u@juno.com
Please help me i really do need help the car has 305 if that helps
not sure as to whether it is tpi or tbi
HELP!!!!
Old Oct 8, 2002 | 09:43 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
https://www.thirdgen.org/techbb2/sea...der=descending
I've never messed with VATS myself but, you might find your answer or at least a direction using the above link.
Old Oct 9, 2002 | 12:51 AM
Car: 86 Z28
Axle/Gears: TBD
thanks bird
if anyone else has help i really could use it
Would it be easier to to and just replace column?
how do i get starter to bump motor over so i can make sure its not locked up.
Old Oct 9, 2002 | 03:55 PM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
To get the car to crank you will need to jump the starter enable relay. On most models it's located under the driver side kick panel. This relay is controlled by the VATS decoder and ECM. It is simply a relay BEFORE the starter solenoid effectively removing the voltage from the solenoid unless the proper pellet key is used.
Old Oct 9, 2002 | 03:58 PM
Car: 86 Z28
Axle/Gears: TBD
update....oh shht!!!!!!!!!!
ok here the deal the current owner says the chip is missing from the key. what do i do now?
Old Oct 10, 2002 | 12:53 AM
86LB9's Avatar
In my honest opinion, find something else. The chip is missing out of the key?? And the column is messed up so bad that the ignition doesn't work?? Sounds like the car is stolen or was attempted to be stolen. How did he drive it? I'd check the title and make sure he is the owner of the car. Otherwise your getting yourself into something that you don't want to be. I was put in the same situation with an 89' Mustang GT. I ended up losing the car over it. But if you don't care and just want the car like I did, search the forum....you'll find your answer.
By the way, if you want to know if the car is TBI or TPI.....pop the hood, unless of course the hood is welded shut too
Old Oct 10, 2002 | 10:10 AM
Car: 86 Z28
Axle/Gears: TBD
some one tried to steal it with no luck
the owner happened to lose chip while the car was sitting waiting to be repaired. to day i'm going over there to bump starter over. if motor spins if it does, then i'll get it. can't really beat $500 with clean title. i've seen the outside and interior but haven't opened hood yet. wish me luck
will the new steerig column fix this prob? will cost me about $100
or will i end up towing it to a dealer.
antman89iroc
36
Jan 31, 2016 08:42 AM
cheesehomer
Dec 31, 2015 08:48 AM
BrianI
Oct 3, 2015 12:57 PM
mfp189
Sep 27, 2015 09:25 AM
PeteK825
Sep 22, 2015 10:47 AM
