85 tpi dash to 84 berlinetta dig dash
Old Oct 9, 2002 | 05:17 PM
gta007's Avatar
Car: 89 FORMULA 350 / 1991 RX7
Engine: 5.7 L98 / LT1
Transmission: 700R4 / 6 speed manual
Axle/Gears: 3.42 posi / 4.11 posi
ok i have a 85 tpi z28. i was wondering what parts i need.i have intire dash & gauges. could someone help with the wiring. thanks in advance
Old Oct 10, 2002 | 07:27 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
You will need a lot more than just the complete dash if you plan to make this swap a reality !! Here is a short list of things I can recall off the top of my head from when I swapped the digital dash OUT of an 85 Berlinetta and installed an 86 Z28 dash in it's place:
Heater boxes (both sides of the firewall)
Steering column
Floor console
Wiper motor
Wiring harness from the fusebox to the back
Rear light harness
In my case the firewall connector was pretty close to the same thing the 86 Z was equiped with an LG4 just like the Berlinetta. The only real difference was the wiper motor wiring. In your case there will be more significant differances like fuel injector wiring to the fuse box, fuel guage wiring (if the TPI fuel pump is in the tank) and so on.
Good luck with your swap !!
Old Apr 17, 2009 | 12:52 PM
4yoto24's Avatar
Car: 84 camaro berlimetta
Engine: 305 5.0
Re: 85 tpi dash to 84 berlinetta dig dash
i want to do this as well, i want to swap out my dash of my 84 berlinetta ,i hate it, can i have some help and around how much its gona cost.
Old Apr 20, 2009 | 08:04 PM
SLOWMARO355's Avatar
I always see these in the junkyard. Nobody never pulls then
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Dec 6, 2015 11:25 PM
gta90
Sep 15, 2015 04:00 PM
IBrockZ
Aug 20, 2015 12:20 PM
Sanjay
Aug 12, 2015 03:41 PM
