Is there a main circuit beaker?
Old Oct 13, 2002 | 05:43 PM
SRD's Avatar
SRD
The reason I ask is because my tach will start to jump and twitch up and down untill all power cutts out. No juice to anything. Eventually , up untill today, the power comes back and I am fine for a while
If there is a main circuit breaker, what would cause it to shut off after my tach wiggs out.
And where is this supposed circuit breaker located?
Thanks, I am stumpped
btw ( Cap, rotor, plugs, wires, and battery are all new)
Old Oct 15, 2002 | 06:24 PM
SRD's Avatar
SRD
COme on boys, SOmeone has to know whether there is a main breaker or not. HELP
Old Oct 15, 2002 | 06:49 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There isn't.
Old Oct 15, 2002 | 07:00 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
All power to loads is routed through 3 fusible links from the large lug on the starter and there is also a fuse or fusible link from the + terminal on the battery to power the ECM & fuel pump. The power leads from the starter lug are routed through the bulk head connector @ the driver's side fire wall, except for one, which powers the alternator field.
Old Oct 15, 2002 | 11:12 PM
SRD's Avatar
SRD
Thanks TIm. I guess I'll have to just start visually inspectng every inch of wire in order to figure this out.
NO links are blown and the power eventually comes back on
why would all power disapear at once after my tach wiggs out, then come back on shortly after?
Old Oct 16, 2002 | 09:09 AM
When power goes out, use a volt meter to probe the fuse panel & then move back toward the source to see where the break in the circuit is. The fusible links sometimes have an intermittant connection where the short thin "fuse" wire is bonded to the large wire - in the plastic encapsulation.
Old Oct 16, 2002 | 12:51 PM
SRD's Avatar
SRD
So its possible that a fusible link is faulty and cutting out?
$750 L98
Feb 1, 2025 02:25 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
efiguy
Sep 27, 2015 01:30 PM
