Interior Electrical Problems
Old Oct 16, 2002 | 12:43 PM
Pillage's Avatar
I have a 89 iroc 305 tpi. The horn, cig-lighter, cruise, dome-light, mirror lights, power-mirror, power-locks, and hatch button do not work. no blown fuses. Is there a relay under the dash or something that might be blown?
Old Oct 16, 2002 | 04:16 PM
Harley61's Avatar
Car: 90 RS / 89 IROC
Engine: 305 TBI / 305 TPI
Transmission: 700R4 / T5
Axle/Gears: 3.73 / 3.08
I would check fuses again, I had the same prob and it was a fuse. Also, all those are on the same fuse.
Old Oct 16, 2002 | 05:36 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
(The ACC fuse)
Old Oct 17, 2002 | 12:35 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
check the fuses again, and look for obvious things, like something stuck in the cig lighter. i almost started ripping into my elec. system because of a stuck dime in the bottom of the cig lighter socket. couldnt see it because it fits perfect, and goes allll the way to the bottom. it will knock alot of stuff out elec wise. good luck...electrical gremilins are a pain.
justin
Old Oct 17, 2002 | 06:42 AM
Pillage's Avatar
Fuses are all ok and i even unplugged the cig lighter electrical connections so we can rule the lighter out as a possible problem. Any other ideas?
Thanks everyone.
BRoss99
Aug 10, 2025 05:08 PM
Thomas
Oct 3, 2015 05:34 PM
Dialed_In
Aug 20, 2015 01:45 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
