vss question
Old Nov 20, 2002 | 04:36 PM
blackacidevil91's Avatar
vss question
I got a 91 z28. Does the vss send a signal to the ecm and the ecm send a signal to the speedometer or does the vss just send stright to the speedometer?
Old Nov 21, 2002 | 09:42 PM
Vader's Avatar
I'm not sure on a '91, but on earlier models the VSS signal is split at a buffer module attached to the back of the speedo.
Old Nov 21, 2002 | 10:14 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: vss question
[QUOTE]Originally posted by blackacidevil91
[B]I got a 91 z28. Does the vss send a signal to the ecm and the ecm send a signal to the speedometer ]
Yes, that is the way it works.
Old Nov 22, 2002 | 12:02 PM
long&low's Avatar
Car: 88 ext.longbed 1/2 ton
Engine: TPI 350
Transmission: Slushbox 400
If it is a TPI car it works that way.
The TBI cars had the VSS Buffer seperate from the ECM.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
GTAman
Aug 27, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
fonzie85
Aug 13, 2015 11:50 AM
mizz0313
Aug 12, 2015 06:45 AM
