Vats or bad ground connection? Please help!!!!!!
Old Nov 21, 2002 | 11:18 PM
JDV's Avatar
JDV
Today when I went to start my car the damn thing would not turn over. It will do this sometimes here and there. I thought it was the vats system. But I noticed that the fuel pump was coming on every time that I went to start the car. And the security light was not flashing. I think if the vats is not working it will not let the fuel pump work. When this happened, me and my friend got my jumper cabels,and went to make a ground to the battery. We put it to the negative post,and then hooked the other side cable to the engine. Sure enough it started right up. Now was this just good timing and the vats decided to work or is it a ground problem to the battery?
Old Nov 23, 2002 | 12:22 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
sounds like a ground problem, clean the neg batt cable at the batt and the engine(or frame), if it is to the frame, clean the eng-frame ground cable, if it still does it, remove the starter and clean the block and starter mating surfaces, if you need it fixed fast, go to the auto parts store, buy a long batt cable (60 in.?)w/ lugs on both ends and run it from a starter bolt strait the the neg batt terminal
Glowsock
Jul 24, 2025 03:15 PM
Glowsock
Aug 31, 2015 09:01 PM
Jae992
Aug 27, 2015 09:07 AM
djmarch
Aug 19, 2015 12:07 PM
stalkier
Aug 13, 2015 12:59 PM
