Heater blower doesn't blow!!!
Old Nov 23, 2002 | 08:53 PM
vrooom305's Avatar
My AC/Heater doesn't blow air!!! The I feel hot and cold air but when I try to increase the fan speed nothing happens. What could be the problem? Please help me IT'S COLD!!!
Thank's
Old Nov 23, 2002 | 11:28 PM
spitz74's Avatar
It's almost certainly the fan blower motor. They commonly go out. But fortunately, they're not too expesive (about $40). And, they're pretty easy to replace (But it's been a couple of years since I changed one). It's a little electric motor about the size of a softball on the passenger side of the firewall on the heater box assembly. Before you replace it, though, be sure and check your fuses. If the fuses are O.K., and you replace the blower motor, and it still doesn't work, the next part to replace is the fan switch in the HVAC controls in the dash. It's a little ($15) part (but they die less frequently than the motors). You will not need to replace the entire HVAC control assembly. I hope this helps!
Old Nov 24, 2002 | 12:07 AM
vrooom305's Avatar
Thank's for your help. But what coes HVAC mean?
Old Nov 25, 2002 | 05:05 PM
spitz74's Avatar
I'm pretty sure HVAC stands for either "Heater Ventilation Air Conditioning" or "Heater Vent Air Conditioner." Depending on who you ask, they may change the endings of the "Vent" and "Air Conditioning" terms. The HVAC control is the in-dash control panel above your stereo head unit. (It took me a long time to figure out what HVAC meant too).
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
64goatman
Sep 9, 2015 01:09 PM
scottmoyer
Sep 7, 2015 07:06 PM
90formulaVortec
Sep 3, 2015 09:26 AM
