Firing order... is it #1 or #2???
Old Dec 2, 2002 | 11:47 AM
tazmision89's Avatar
Ok guys, I just installed a new MSD blaster coil, plus rotor and cap and new MSD wires. The car seems to hesitate a bit on a stop and the volt meter jumps like something is wrong. Now this is how the wires are set on the car. Is this the correct setup?
Old Dec 2, 2002 | 11:48 AM
or is this one the correct setup? Any help will be greatly appreciated
Old Dec 2, 2002 | 01:16 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I think that from the factory HEI systems looked like the second picture you posted and older points systems looked like the first.
As long as the rotor points to the right wire at the right time, you can start them wherever you like.
Old Dec 7, 2002 | 11:13 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Just put #1 at top dead center and pull your rotor cap off and make sure the rotor is pointing at #1 spark plug wire. Then run them from there.
KCG
Jun 24, 2020 04:33 AM
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
indygene
Sep 26, 2015 11:21 AM
