Fuel Pump Relay Wires
Old Dec 4, 2002 | 09:35 AM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
hey, i think ive found the fuel pump relay, which could be causing my starting problems. I know i need to do a continuity check with it, but im not sure which wires to do it across. any help is appreciated! thanks
Old Dec 4, 2002 | 03:22 PM
Jza's Avatar
Jza
Check continuity from:
1 Black/white to ground
(if no, relay needs to be grounded)
2 Black/white to green/white
3 Grey or white or whatever they use on 88s to red (if 88s even have a red wire; they changed so many times from 86 to 90 I can't even keep track of it)
(if no on either of these, relay is bad)
Run 12V to the red wire to test the fuel pump.
Orange wire should have constant 12V.
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Kaweh
Aug 9, 2015 02:54 PM
