View Poll Results: how many of you have had this damn problem
Ive never heard of that
0%
I have had that problem as well
0%
Voters: 0. You may not vote on this poll
Reverse sensor in tranny... *** help me.
Old Dec 17, 2002 | 10:18 PM
84Z28_5.7ltr_V8's Avatar
Car: 1984 Z28
ok, i have a plug in my transmission that i am assuming is the reverse lights switch. I have seen one of these plug things on many other cars so, i guess im positive thats what it is... . Anyways, my question is, where is the wire coming out of the socket supposed to go to. I dont have the plug that should go into the socket but i am rtrying to find one so i can get my reverse lights to work.
so i need a plug, then i need to know what i would connect the wires that come out of the plug into.. the fuse box? or the ...?
Old Dec 17, 2002 | 10:31 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If you're talking about an automatic tranny, I believe that's for the converter lock-up (ECM controlled). The 'switch' for the reverse lights on an auto is part of the park/neutral switch on the shifter.
A T-5 trans. has a reverse switch on it in the middle of the casing on the drivers side w/2 wires.
Old Dec 17, 2002 | 10:36 PM
Car: 1984 Z28
thats what i have, the socket plug in thing on the drivers side kinda in the middle. but i have a 5 speed... i have a chevette and its the exact same thing... but obviously its a completly different tranny... but same set up.
Old Dec 17, 2002 | 10:50 PM
deadbird's Avatar
Engine: TPI 305/ v6
On a T5 you should have a blue and green wire (I've seen mine more times that I've wanted so it's easy to remember ). If I remember right, the reverse lights are tied into the turn signal flasher wiring 'turn b/u' fuse. The blue wire comes from the flasher to the switch (on the trany) which closes (completes the circuit) in reverse and the green wire send the power to the b/u lights.
The wiring from the tranny leads to the bulkhead connector (next to the brake booster) and the rest is wired w/in the car (excluding the actual tail lamp wiring at the back of the car)
Old Dec 19, 2002 | 07:11 PM
Car: 1984 Z28
any pics or websites i can check out?
Old Dec 19, 2002 | 10:38 PM
deadbird's Avatar
Engine: TPI 305/ v6
Old Dec 21, 2002 | 02:57 PM
Car: 1984 Z28
that should work, i hope. but if someone happens to have like color pictures of how they wired it, post it please. thanks.
GTAman
Jul 3, 2024 07:29 PM
nova983
European Region
Nov 2, 2015 12:15 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
FormulasOnly
Sep 10, 2015 09:07 PM
Stryker412
Sep 7, 2015 09:11 AM
