Advise on the H4 conversion - My story
Old Dec 18, 2002 | 10:19 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I bought the "direct drop in" H4 conversion on ebay from some Kioto International seller. When I plugged them on, they were dim, or didn't work. I got my answer to that on these message boards. I needed a new harness with relays and a direct power source from the battery to the lights, instead of the stock routing, battery to switch to lights. Well, it seemed a little out of my league, so I went to the local car electrician. $300+ for labor, and that wasn't including any parts! I was about to just say screw it when I say a little thing in the Jegs sport compact section. I WAS BORED, I HATE R*CERS!!!!
I came to an interesting find, and decided to order it. It was a Painless wiring harness made for the H4 conversion in an older car. When I got it, all I had to do was plug one of my old connectors into it, and the 2 to my new bulbs. Then I grounded it and ran the last wire to the battery. I pulled the light swich, and VOILA! It worked! Here's the part # for anyone with similar problems:
Painless Performance Products - Headlight Relay Conversion Harness - P/N 30815 Jegs part # 764-30815
This isn't an advertisement or anything, just want other people to have it easier than I did!
Old Dec 19, 2002 | 08:20 AM
luvrgodd's Avatar
Car: 02 Z06
Engine: LS6
Transmission: MN12
what is an H-4 conversion??
Old Dec 19, 2002 | 09:52 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
The H4 conversion is the "blue" headlight setup avalible for the 3rd generation Camaro's and Firebirds.
Old Dec 20, 2002 | 10:59 AM
luvrgodd's Avatar
Car: 02 Z06
Engine: LS6
Transmission: MN12
where do i buy something like that from? i have a 82 TA will it work on my car? anywhere besides ebays that i can buy it from?? by the way, have any of you guys ever tried to change the color of the front turn lamps away from that ugly yellow??
Old Dec 21, 2002 | 11:19 AM
JPrevost's Avatar
Car: 91 Red Sled
I also bought those lights and they are VERY dim with stock wiring. I'm going to try and just hotwire them directly to the battery to see if it improves any. I'm in the process of doing some more wiring to the car, hopefully this fixes the issue.
Aaron, did yours come with the little blue parking lamps build in and with that "oncoming traffic bulb cover" sheild? If so, then we've got the same units. I'm junking these bulbs. They're so cheap and don't work on the low beam setting. It's SO dim that my little flashlight works better. Even the high beam setting is dim. Not to mention the beam projection isn't flat, it's round so it's more like driving lights. You'd be best off going with a set of $20 fog lights that light up the sides of the road and using the headlights for the road.
Old Dec 21, 2002 | 02:05 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Yes, mine have the blue lights in the corners. If yours are dim, you definately should disconnect them and put the stock ones back in. Those lights are trying to pull too much power thry the small stock wires and may cause overheating, leading to a possible fire! I had the same problem, but got the harness and all is well now. I also have the stock foglights, but added the blue Xenon bulbs to those as well. Now with the low beams and the fog lights, I can see forever down the road!
Old Dec 21, 2002 | 08:05 PM
Teds92RS's Avatar
Car: 1989 Camaro IROC-Z
Engine: Lt1
Axle/Gears: Quick performance 9" 4.11
whoops, computer froze and it posted twice
Old Dec 21, 2002 | 08:06 PM
Teds92RS's Avatar
Engine: Lt1
Damn guy's, what timing...lol I found this kit on ebay and I'm trying to get it (my Christmas present from my parents) Now if I buy 2 kits, will my high beams work with these bulbs? meaning after I hook up the bulbs and pull the lever for my high beams, will they get brighter? To make sure these are the same kits we are talking about, here is the link: conversion kit
Thanks, Ted
Old Dec 21, 2002 | 09:41 PM
Teds92RS's Avatar
Engine: Lt1
please guy's, I need help fast...This is suppose to be my Christmas gift....lol
Old Dec 21, 2002 | 11:58 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Ok, looks the same. I thought of trying 2 kits, but you'd have to create your own wiring. I don't know if there are dual range H4 bulbs... y'know, they'd have 2 filaments, one for low beams, and both for high.
Old Dec 22, 2002 | 12:18 AM
Teds92RS's Avatar
Engine: Lt1
Oh ok, Ill just buy one set then. Maybe if they look totally different, I'll buy newer housings of the same style as th H4's. So tell me about the little blue marker lights. If you have them wired to your parking lights, then do they light up the inside of the housing blue?
Thanks, Ted
PS Do you have aol or AIM? my name on aol is DBIronmen3, it would be easier to talk
Old Dec 22, 2002 | 11:38 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Well, I'd be careful with those. If you do get the light conversion, connect up the little blue bulb in the corner, you'll see that it makes the whole light as blue as the "blues" on a cop car. I guarantee that you'll get nailed for 'em! I put red ones in (My car is black with a red interior, and I have the Street Glow red's under the car, inside the car, etc.) and just turn those on when I'm at the track. With my headlights glowing red and the underside as well, it looks damn cool!
Old Dec 22, 2002 | 11:54 PM
Teds92RS's Avatar
Engine: Lt1
awesome man! a guy at my school has the same thing in his lights on his car. It looks hot!
~Ted
Old Dec 22, 2002 | 11:59 PM
Teds92RS's Avatar
Engine: Lt1
one more question, with this conversion can you now drill into the housing if you want to put strobes in it or something, or is it still a sealed beam like the stock ones?
Thanks, Ted
Old Dec 23, 2002 | 10:54 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
It's only a housing, the H4 bulb is the only sealed part. I'd say, drill away!
Old Jan 1, 2003 | 12:31 AM
355formulatpi's Avatar
You can do pretty much the same thing with a couple of relays! I did this to my stock lights, and noticed a HUGE difference in brightness! I measured the voltage before(going through the stock wiring) at 10.5volts at the headlights, after a couple of relays triggering power directlly off the battery, it was 13volts. That is a 2.5 voltage increase at the lights, and they are as bright as (almost)any new vehicle!! Later!!!
bryanwood74
Sep 24, 2015 09:50 PM
stalkier
Aug 21, 2015 01:54 AM
ssxmac
Dec 19, 2013 10:42 PM
WileECoyoteSr
Jan 31, 2012 07:51 PM
Blazer406
Brakes
Sep 5, 2007 01:45 PM
