1LE front brake conversion on IROC...still won't stop...
Hey guys... a buddy has an '88 5.7L Iroc with the J65 brake option.
The car has been converted to a turbo Buick V6 and a TH400 trans. First time to the track....car went 134 mph through the traps....and had a very hard time stopping.
Mods to the brakes at that point: none.
Since then.... the original rear was pulled in favor of a Ford 9" that had been completely built for a F-Body..... it has drum brakes....torque arm... just like the factory. At this point...the rears locked up much too soon... and I advised he install an adjustable proportioning valve on the rear... and fine tune his bias.... which he did. Around the same time.... he bought a 1LE complete front brake setup off a turbo trans am.... spindles... calipers... and all... They have been installed.
He has been advised that he needs the 1LE proportioning valve to make the brakes function properly. The more I read.... I disagree. He has the factory disk/disk proportioning valve.... and an adjustable proportioning valve on the rears.... so he can get his brake bias perfect. I just don't see how a different proportioning valve can do anything any better than that.
He has purchased the 1LE proportioning valve.. but we haven't installed it. I read his car is a "1st design" proportioning valve... and likely has 1.0mm pitch threads. I read that the "2nd design" has 1.5mm pitch on the threads..... so I don't even think it will bolt up to the stock lines.
Since the motor is turbocharged.... I am leaning toward a hydroboost conversion. I think his car just isn't making enough vacuum with his cam... + it is turbocharged..... this lack of vacuum is probably causing low pressure at the calipers/wheel cylinders..... all of which can be rectified with a hydroboost conversion.
Any thoughts?
Any thoughts?
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Re: 1LE front brake conversion on IROC...still won't stop...
Is there a different cam in the motor? If it is basically stock. I garontee he has enough vacume. If you want to know for sure why not just check with a vac. gauge?
Then if he is still only pulling like 6-9" of vac. Buy a vac. res. can for $20 from summit. That will leave him with enough vac when it comes time to push the brakes.
I used to only pull 6" of vac, and I ran a can, and was fine for the street. I now pull about 9" but still run the can. Of course still fine.
Much cheaper than that hydroboost stuff.
Does this sound like a good plan? I wonder how many inches of vacuum that one of thos pumps can pull? I would assume the more vacuum it can pull the better the brakes will be.
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
0 vac at WOT (after a pass) so theres nothing in the reserve, i would go hydroboost. My car had a problem shutting down after a pass so i put bigger ls1 brakes on it front and rear now stops just fine
Engine: LS3
Yeah, but when you are idling before a pass you have already filled the reserve. there is a one way check valve you are supposed to install so that anytime you make vacuum it gets "saved" up in there for later use. I have been in the office right now for 1 hour, but i know that my car still have vacuum waiting in the can for me when I want to use it, even with the car off. So saying that you have none on reserve after a run, if you are running a can, is just plain wrong. Or installed wrong.
I agree you should be able to store vacuum and it be there after the run.......
I also think his cam may not be generating enough vacuum to get enough assist from the unit.
I also think the vacuum pump we have isn't going to pull enough vacuum to work real good... only 5-6 in.... I plan on measuring it soon.
I had visions of an intermittent use pump... that could generate 20 in of vacuum and provide considerably more assist than we are currently getting. I am not sure how realistic that goal is... or if 20 in of vacuum will make the brakes apply harder.
I really think the 12" 1LE brakes ought to work great..... stock TTA's came with those brakes... and they would go 162 mph right off the showroom floor.....
Your factory original combo vavle is shot. You are loosing brake pressure because the vavle is malfunctioning and causing blockage.
Put the new one in and it will solve your problem. The additional rear prop valve (wilwood valve I am assuming) is really not needed. It was a bandaid fix to the bad factory combo valve and the fronts degrading- you were having to turn the rears down also.
As far as the factory combo valve.... we were going to replace it with a real 1LE valve... but the brake bias is still going to be off because it has the drum brakes. The 1LE combo valve is for disk/disk...... so IMHO... the chance the brake bias beeing correct is nil.
