berlinetta no headlights... help
Old Dec 19, 2002 | 01:49 PM
macone's Avatar
my headlights have gone all of a sudden. seems nobody knows how to deal with this situation. is there a relay that would have blown? or is it for sure the switch? there is still an audible click sound when you turn them on, and all the back up lights still work ???
has anybody run into this problem before?
oh ya star wars dash on this one.
Thanks gang
Old Dec 22, 2002 | 11:43 AM
macone's Avatar
is there a relay between the switch and the headlights??
Old Dec 26, 2002 | 03:04 AM
MdFormula350's Avatar
see if this helps
Old Dec 26, 2002 | 11:42 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
You need a new (or replacement) Light Module. The image above is from a "normal" camaro and does not represent the wiring diagram in your car. Your car contains special features that were unique to the 84 thru 86 Berlinetta, Like:
Auto off headlights (When ignition is turned off)
"Flash to pass" high beams
Timed courtesy lights
Ect......
The light module is located under the passenger side of the dash and is attached to the ECM by 4 10mm nuts. It is a black box and has 3 wiring harnesses plugged into it.
I sell replacements if you can't find one locally - just contact me for details.
Old Dec 27, 2002 | 10:03 AM
macone's Avatar
Thank you very much John, I am tracking down this module now. hopefully it is avalible at the dealer
Lbibb
May 5, 2016 12:00 AM
Linson
Oct 1, 2015 09:50 PM
rusty vango
Sep 29, 2015 02:44 PM
RacerM
Sep 28, 2015 04:25 PM
manifoldsrme
Sep 17, 2015 11:40 PM
