anyway to replace headlight motors with better ones?
Old Dec 21, 2002 | 11:24 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
mine make a lot of noise and are kinda slow........i have a friend that has a probe and his are really quiet and smooth.......is there anway i could get some type of motor that would be quick/quiet like that?
thanks
Old Dec 24, 2002 | 08:43 PM
BlackBeast'88's Avatar
Car: '88 Formula
Engine: 355cid
Hey you need to check out Steve's site. Click on the link below. I repaired my drivers side headlight after following his instructions...
http://www.transamtemple.com/modific...ght_repair.htm
Old Dec 25, 2002 | 07:53 AM
Egglick's Avatar
Sounds like they might be on their way out, but as long as they're still working correctly I wouldn't mess with 'em.
Maybe just read up for now to see what you'll need to do, if and when they break.
Old Jan 1, 2003 | 12:22 AM
355formulatpi's Avatar
4th gen headlight motors will fit! I put them on mine! U need some spacers, about 1/2 inch, and u need to drill new holes! The wireing is backwards! 87-92 2wire (green, and a grey with black) The 4the gen have the same colors, but u have to connect a green, to a grey/black...ect! Hope this helps! Later!!!
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Leggman1
Aug 6, 2015 04:15 AM
