need help identifying this mystery wire (disconnected)
Old Dec 22, 2002 | 05:49 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
anyone know what this is for and where it plugs into???
its been unplugged for as long as i know...
Attached Thumbnails need help identifying this mystery wire (disconnected)-dunnowire.jpg
Old Dec 22, 2002 | 05:50 PM
Diggler86's Avatar
Car: 86 TA
PS colors are purple and yellow.
Old Dec 22, 2002 | 09:27 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
They look like fairly heavy gauge wire compared to the courtesy light wire. As a guess it may be a pre-wired neutral start switch if the car had become a 5-speed.
Old Dec 24, 2002 | 12:31 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
does that go to a switch on the brake pedal? Or is there an empty plug end inside the kick panel(lower dash panel) there?
Old Dec 24, 2002 | 11:02 AM
Diggler86's Avatar
Car: 86 TA
i never found anywhere to plug it into, which is why i was wondering if it should be plugged in somewhere!
Old Dec 25, 2002 | 04:15 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
If your clutch pedal weren't missing, it would hook up to a connector attached to it...
It's nothing to worry about; like deadbird said, it's for the clutch pedal's neutral safety switch.
Pete
Ghettobird52
Jul 5, 2024 11:18 PM
diana227vegas
Jul 8, 2016 12:27 AM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Linson
Aug 21, 2015 02:12 PM
Ozz1967
Aug 16, 2015 10:23 PM
