speedo cable
Old Dec 28, 2002 | 12:54 PM
iroc2nv's Avatar
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
speedo cable
does anyone know how to get the speedo cable out easier then the ways outlined before?? my hands are too big to do it the way they say to do it..
thanks for any help
iroc2nv
Old Dec 31, 2002 | 11:45 AM
Vader's Avatar
If you're only replacing the inner cable, I've found it easier to remove and install from the bottom (at the transmission). If you're replacing the entire cable assembly (jacket and all) you have little choice but to remove it at both ends. Disengaging the cable sheath from the rear of the speedo head is a real treat, huh?
Old Dec 31, 2002 | 01:29 PM
iroc2nv's Avatar
Axle/Gears: 3.45
yeah,
all i did was take those 2 13 mm bolts off the steering column drop the column a bit take the cluster out enough to get my hand behind the dash and voila...
thanks for the reply though
iroc2nv
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
