tach needle stays at 0..
Old Dec 29, 2002 | 10:06 AM
iroc2nv's Avatar
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
ive since installed my macewan gauges...
but now the tach needle doesnt move when turn the car onto the on position(it drops right to 0) and then when i start it and give it gas (to about 2500) it starts to move..
how do i go about getting this fixed..
thanks alot
iroc2nv
oh if this helps i took the needle off when the car was off but the needle was at approx 2500rpm (all the other needles seem to be working)
Old Dec 30, 2002 | 01:27 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: tach needle stays at 0..
[QUOTE]Originally posted by iroc2nv
[QUOTE]
By this do you mean it as in, starts to move normally ?
Just because the needle was at 'X'rpm when you popped it off...doesn't mean it stayed there.
If the needle moves as normal after 2500, I'd (personally) pop the needle back off while car is running at normal temp/idle and place it back on closely to where I believed it normally idled. Or.. it's just broke... I"m only guessing anyways
Old Dec 30, 2002 | 06:27 PM
iroc2nv's Avatar
Axle/Gears: 3.45
yeah i did thatl....it just came to me to try it..
but thanks for the response
iroc2nv
$750 L98
Feb 1, 2025 02:25 PM
sheachopper
Jul 31, 2019 11:27 AM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
