no blinker??? pse help
Old Jan 2, 2003 | 02:57 AM
muffler's Avatar
like post said i have no blinker. i have replaced the bulbs(all)the round blinker thing .
is there a relay on this thing that i dont know about or should i replace the blinker arm in the column? i dont want to pay the dealer to fix this thing cause electrical problem cost alot
Old Jan 2, 2003 | 09:02 AM
DuffMan's Avatar
Car: '99 Cobra
Engine: 4.6 DOHC 32V
Transmission: T-45
Axle/Gears: 4.10
same problem!
I replaced my DRLs, and when i was done, i realized the right DRL was dimmer than the left one, but what was odd, was that the right one is able to flash, but the left one is not
i switched the bulbs to see if i had gotten a bad bulb, and then i turned the parking lights on. now, the right one does not work at all, and the left one is as dim as the right one was before!
im pretty stupmed too, altho im sure it simply a shorted wire/blown fuse
any ideas anyone?
Old Jan 2, 2003 | 11:33 PM
racerx004's Avatar
Check to see if your hazzard flashers are working o.k. If they are then try checking the flasher unit under the dash on the drivers side.
If you were sitting in the drivers seat it would be above your left leg.
There are two flasher units in there, one for the directionals and one for the hazzards.
Switch the two then try, your directionals, if they work then you know you have a bad flasher unit.
Don't leave the two flasher units switched around though, or you will ruin the hazzard flasher.
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Jk_Under
Sep 2, 2015 10:59 PM
bklucas12
Jan 11, 2002 06:44 AM
super83Z
Jun 2, 2001 10:44 AM
Jimmy91RS
Sep 28, 2000 02:16 PM
