Fuse panel dead?
Old Jan 9, 2003 | 12:53 PM
Art92RS's Avatar
Fuse panel dead?
My 92 RS is having some electrical problems lately, and they other day she just went dead. From probing around the harness, I beleive everything is dead. Is there some main terminal where it gets power from?? I have no idea where to start on this, Im horrible with electrical stuff. Please help.
Old Jan 9, 2003 | 06:30 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
Need a bit more info if possible. What sort of problems did you have before?
Is the alternator and battery good? Were they functioning properly? Is there any power anywhere? The fuses ok? Fusible links?
Give a bit more info and we may be able to help you out.
Old Jan 9, 2003 | 08:30 PM
Art92RS's Avatar
Well the batt and alt were recently replaced. I tested them both adn they are fine. Before my car stopped running the acc. circuit fried after i replaced the fuse. No lights, radio, nothing.... but the buzzer when you put the key in still works so it has to be getting power from the battery still. All fuses are ok, im not sure where the fusable links are?
thanks for replying
Old Jan 12, 2003 | 02:06 PM
MdFormula350's Avatar
i believe there is a fuseable link or two alittle bit after the battery in the engine bay, maybe check those..
Old Jan 12, 2003 | 04:01 PM
Matto'85TA's Avatar
I heard they may also be located near the starter.
thunder57
Nov 7, 2015 02:28 PM
92projectcamaro
Sep 29, 2015 07:07 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
raymondandretti
Sep 27, 2015 06:43 PM
lanceflame44
Sep 25, 2015 12:28 PM
