Headlight controll module question.
Old Jan 14, 2003 | 02:04 PM
89_305TransAm's Avatar
Car: '89 Firebird Trans Am WS6
Engine: 305 TBI (L03)
Ok..I have what I think to be a legit question here..
My one headlight, does not go up and down like it should.
I plugged the "dead" motor in on the other side and it works, so that tells me the motor is good, the line is just dead.
So i located the HCM on the firewall and it has 2 plugs comming out of it..
One for the left, one for the right i would guess..
Now if this is true so far, could i theoreticly plug them in the oposite socket, in reverse, and see if the opposite side works and the other side stays down? Then I would know its definitly the module that needs replacing.
Hope you get what im saying, lol
-Joe
PS: its a 89 trans am
Old Jan 14, 2003 | 10:56 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
It's a good theory but, it's not correct.
One side is power & headlight switch 'signals',
the other is to the headlight motors.
This may help your elimination process.
Old Jan 15, 2003 | 02:03 PM
Another theory shot to hell. ;(
Is there anyway to check the HCM to see if it is that that is at fault?
Old Jan 15, 2003 | 11:19 PM
TA Terror's Avatar
What I did was pull out the "dead" motor and plug it in to the connector on the "good" side. The motor was alive! So I went to the junkyard and pulled a HCM out of a wreck, installed it, now everything works great!
Old Jan 16, 2003 | 06:34 AM
Did that exact same thing, if that means its the HCM, ill go get a new one.
Old Jan 17, 2003 | 06:40 PM
Vader's Avatar
Headlight Control Module? Mine still has the indivisual motor relays and isolation relay. When did it change to a single module?
Old Jan 18, 2003 | 09:09 AM
patrickm00's Avatar
87 (or, at least sometime during 87)
Old Jan 18, 2003 | 03:30 PM
Yep motors changed over in 87.
I just bought aHCM on ebay , lets hope that is my problem.
TrevinE
Sep 14, 2015 03:20 PM
dbrochard
Sep 7, 2015 09:41 AM
Jlanz55
Sep 6, 2015 02:35 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
