ghost is my rear defrost...
Old Jan 17, 2003 | 01:17 PM
joshp14's Avatar
today i turned on my defrost and i looked down after 2 minutes and it wsa off. so i turned it back on and then it turned off immediately. i then pushed the button, and when i pushed it a wierd buzzing noise came from inside the dash on the passenger side. i waited, then tried it again...it turned on but only for a sec. it wont stay on, all it does is turn off by itself. do these switches turn off after a certain amount of time? or is sumthing broken?
Old Jan 17, 2003 | 02:23 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
I think they stay on for like 10 minutes. It sounds like it may not be grounded. Check the hatch struts and see if the wires are connected. Check to see if the ends of the struts are on properly. If they are I suppose it could be a faulty switch.
Old Jan 17, 2003 | 04:35 PM
Morley's Avatar
Don't have a rear defrost in mine, but aren't they operated from a timer relay? The buzzing sounds like a relay that won't stay engaged.
Old Jan 17, 2003 | 11:39 PM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
if it came from the passenger side then that means 1.its a firebird and 2. you need to replace your relay. mine did the same thing in my camaro i replaced the relay and it works fine now.
Old Jan 18, 2003 | 12:18 AM
MdFormula350's Avatar
yeah the noise is most likely the relay...
Old Jan 18, 2003 | 11:41 AM
joshp14's Avatar
can i get the relay from autozone or advanced auto? or only from GM? how much do they run?
Old Jan 18, 2003 | 12:22 PM
HamSpiced's Avatar
yes, and about 15 bucks
Old Feb 3, 2003 | 08:14 PM
joshp14's Avatar
i went to local autozone, oreillys, and advance auto, no body has it. is there any other place i can get one?
Old Feb 3, 2003 | 10:03 PM
llvll4l2c91350's Avatar
Most likely this is only a dealer item.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
