Heater/AC Motor Help
Old Jan 24, 2003 | 06:32 PM
OutsiderIROC-Z's Avatar
My heater motor does not blow any air, I have replaced the motor, checked the fuse, and the switch inside the car and nothing has worked. Does anybody have any ideas? I see a little black box/relay on the heater box under the hood that it looks like the wires run to. Could this be the problem? Any help would be appreciated. Thanks in advance.
Old Jan 24, 2003 | 07:30 PM
llvll4l2c91350's Avatar
If it clicks, it's working. See if you can listen to it or feel it with your hand. If it doesn't click then make sure you're getting power to both sides of the relay. The control side and the load side. And check for grounds.
hydrolic144
Sep 8, 2015 06:55 PM
masonta
Sep 1, 2015 06:40 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
slade5612
Aug 11, 2015 07:19 PM
