Berlinetta dig. dash maintenance
Old Jan 25, 2003 | 05:39 PM
xChRiSx's Avatar
how do i open the 2 movable panels of buttons to clean the connections? I pulled and they just moved out, and i didnt even know they did that until now. If i just pry the panel will it come off without breaking or do i need to take out the screw on the bottom?
I think there is a screw on the back but i cant reach it with any normal screwdriver.
Old Jan 25, 2003 | 09:54 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
There is either a Hex or a T-10 torques drive screw at the underside of the console that has to be removed. Then you kinda jiggle it out of there. There is a lare harness on the back, I would not try to take it off unless absolutely essential, other wise you risk breaking it.
Old Jan 28, 2003 | 07:04 PM
xChRiSx's Avatar
berlinetta digi.dash
Thats what i tried at first, but i didnt go through with it bedcause it felt so fragile. I need to clean it out though. I tried spraying electronic parts cleaner between the cracksfor the buttons, and it dried the plastic white but wd-40 fixed the color problem mostly
Old Jan 28, 2003 | 09:02 PM
Mike M's Avatar
help is just a click away
Hi Chris, Contact this guy and he will help you. His name is John.
http://berlinetta.info/home.htm
Old Feb 2, 2003 | 12:20 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
:rockon:
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Fanatic1074
Oct 2, 2015 03:47 PM
Linson
Oct 1, 2015 09:50 PM
sjorgens
Oct 1, 2015 07:54 PM
lewandom
Oct 1, 2015 08:15 AM
