idle drops when i flip on hatch defroster
Old Jan 31, 2003 | 09:51 AM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
Transmission: manual
Anyone know why my engine idle drops whenever i switch on the rear defroster?
Old Jan 31, 2003 | 10:45 AM
Morley's Avatar
Re: idle drops when i flip on hatch defroster
Is the engine actually droping speed or is the tach just showing a lower RPM?
Old Jan 31, 2003 | 10:52 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I have a similar problem when I turn on my rear defrost, the rpm only changes for a second, but the volt gage drops from 14v to about 11v.
Old Jan 31, 2003 | 11:10 AM
Jza's Avatar
Jza
Resistive heating elements take a lot of juice to run. Usually, your dropping idle is going to be because of that higher demand on the alternator. That demand makes the alternator harder to turn so the idle drops until the computer notices and opens the IAC a bit to compensate.
There's not a whole lot you can do about it, really. It may or may not indicate your alternator (or more likely your battery) is getting on the old side, though by no means "bad".
Old Jan 31, 2003 | 03:07 PM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
yeah, i hear and feel the drop and then just noticed it by looking at the tach one day. as long as the heater is active the enging idles lower.
Old Jan 31, 2003 | 03:18 PM
Morley's Avatar
As stated above, the alt is having to work harder and drags the engine down a few RPM's. Its kind of like turning on all your lights at once (hi/lo beam & driving), the engine idle will drop noticably.
Old Feb 1, 2003 | 09:12 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
Thanks for the reply Jza, I was wondering if that drop was normal. Both my Alt and battery are only 2 months old and test great. Thanks again.
Street Lethal
Apr 30, 2019 12:14 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
db057
Sep 4, 2015 07:57 AM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
