ignition timing?!?!
Old Feb 2, 2003 | 05:07 PM
twitchm80's Avatar
ignition timing?!?!
All right, just got this car 1989 Firebird Formula, it has the HEI system, now i had to put a new dist. in it, and To set timing, i put the crank/balancer at the only timing mark i could see on it, then put the rotor at between the 1-8 on the cap, it this right because its not running so any help please!!!
Old Feb 2, 2003 | 06:49 PM
llvll4l2c91350's Avatar
If you put a new distributor in, #1 could be anywhere on the cap. To find it you need to remove the plug from #1 hole and stick your finger in there. When you turn the engine slowly and you stop it at TDC the compression should push your finger out. That's #1 TDC. Now you can look at the cap and wherever the rotor is pointing, that's #1 on the cap.
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 18, 2015 02:28 PM
