fuel pump problem
Old Feb 10, 2003 | 01:31 PM
TRANSAM38387's Avatar
Car: 1987 GTA
fuel pump problem
when the car is cold there is no problem, but after it has ran a while when i shut it off and go to restart it the pump comes on but does not prime up the system. i have a fuel pressure guage and it only gets 20 psi. if i bump the key 1 or 2 times the pump turns back on and i get 42 psi and it starts no problem. i have change the filter and no change. p.s. the car is my 87 tpi 305,thank you for any help
Old Feb 10, 2003 | 06:53 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
Check the fuel pump relay.
Old Feb 10, 2003 | 08:47 PM
Car: 1987 GTA
i change the relay out with the maf sensor relay and still no change, could the pump be going bad, has anyone else had trouble like this. thanks for any help
Old Feb 12, 2003 | 07:48 PM
Kwik89GTA's Avatar
Car: 1989 Bright Red GTA
Engine: Grand Sport LT4
Axle/Gears: 10 bolt 3.73
This sounds like a textbook example of your fuel pump on its deathbed. I had the same problem in my 1989 GTA, changed it with a new only to find that the new one was bad also. If you have never seen the fuel tank on a thirdgen, be prepared for a good days work. They are a pain to get out.
Old Feb 13, 2003 | 04:14 AM
Car: 1987 GTA
yea a friend told me the same thing so i'm ordering a 255 lph from summit. my friend also has a car lift so hopfully that will help make it easier to take out, but you know these cars nothing is easy. thanks for the advice
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
