heated o2 sensor
Old Feb 10, 2003 | 10:51 PM
25THRSS's Avatar
heated o2 sensor
what kind of heated o2 sensor should i buy and how should i wire it up? Does anyone have the ac delco part # for a heated o2 sensor? Thanks
Old Feb 11, 2003 | 03:04 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
just go to any parts store and get a 3 or 4 wire O2 sensor from something GM.
my 98 S-10 has a 4 wire, and some older S10s around 94ish had 3 wire I believe.
They're kinda some $$$ but they last much longer than regular non-heated O2 sensors
Steve
Old Feb 11, 2003 | 03:05 AM
25THRSS's Avatar
What exactly is the benefit of using a heated o2 sensor?
Old Feb 11, 2003 | 08:45 AM
Jza's Avatar
Jza
O² sensors have to be at a certain temperature in order to read correctly. Single wire sensors rely on exhaust gas to heat it. On cold starts, this can take a little while, and the whole time your car is operating in open loop mode. The main benefit is that you can shorten that time, but, you have to have the complimentary PROM programming to go with it. All the heated sensor does is make sure the sensor is hot so the ECM can go into closed loop sooner. The computer will still take the same amount of time to get into closed loop if you don't tell it otherwise. So you're wasting your time and money if you get a heated O² sensor thinking it will be some magic mod or cure for some problem.
Scroll down the page a little ways and you'll see a topic called "wiring a heated O2 Sensor". You might find something about wiring a heated O² sensor in there.
Who told you to get one and what was their explanation?
Old Feb 11, 2003 | 08:47 PM
25THRSS's Avatar
well i want to take my smog pump off and since it directs air into the manifolds and the cat to compensate for the extra gas during open loop, i figured with a heated sensor that it would help the engine go into closed loop sooner and the computer would be able to have the correct mixture sooner.
Old Feb 12, 2003 | 06:12 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
AC-Delco # AFS105 is a heated sensor for a 98 Blazer. It should have the same threads as the single wire. I would argue about the heated types lasting longer. The heated variety costs about double what a single wire unit costs. Before you remove the AIR pump, do you have emission testing? Even if you are exempt as I am they still inspect in most areas for the presence of all required components. As I ponder this, methinks that the heated variety may have the heating element timed. You may want to look into this before you drop the bucks. I remember seeing somewhere that they heat the element up only until the coolant temp reaches a certain point then the heat from the exhaust gas keeps it functioning. Just a thought as I sit through this blizzard.
Old Feb 12, 2003 | 09:53 PM
25THRSS's Avatar
here in va we only have visual inspections, and they very rarely if ever even open the hood, all the do is check for a catalytic converter, thats it. Thanks for the info guys
86IROC112
Nov 27, 2015 09:54 AM
85 Jimmy
Sep 30, 2015 07:56 AM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
fonzie85
Aug 13, 2015 11:50 AM
