wont start with key
Old Feb 24, 2003 | 04:29 PM
Firebird355's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
wont start with key
Ok im in the process of trying to go from a 2.8 to 350 w/out CC. I have all the hot wires run to the starter and tryed to turn over with key but nothing, so i figured id try to jump the sylenoid, and it worked? am i leaving something out?? please respond
thanks
Joel
Old Feb 24, 2003 | 05:14 PM
HotRod's Avatar
Car: 87 GTA
Engine: Eaton Supercharged 350 TPI
I just did the same thing and forgot to have the shifter hooked up. The shifter has to be in nuetral or park in order for the starter soilinoid to get juice.
Tyler
Old Feb 24, 2003 | 09:05 PM
Car: 1991 Camaro RS
Engine: 305 TBI
hmm because shifter is hooked up, like the cables are there and the plug that plugs in the front of it,
anyone else?
Old Feb 24, 2003 | 10:24 PM
HotRod's Avatar
Car: 87 GTA
First check to see if the soilinoid is getting juice with the key in the crank position. If it is, it is a bad soliniod, if not check simple things first like if it is a fuse or bad connection. Do you have fuel injection or did you? What year is the car. If you had or have vats then you need to bypass it. I suppose the ignition switch on the steering column could also go bad so check it. Give us some more feed back and we can help you further.
Tyler
Old Feb 25, 2003 | 02:48 PM
Car: 1991 Camaro RS
Engine: 305 TBI
i dont have vats, its an 88.. the switch in the column worked fine when i tore into the car (end of december '02). ill go test for juice later.
eightsixseven
Dec 16, 2024 01:50 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Jae992
Aug 27, 2015 09:07 AM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
