wiring aftermarket volt guage
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
you can do it a number of way. you can take it from the fuse box, which is the best way. use a key on power on key off power off so it comes on with the ignition.
good luck
good luck
one side goes to a body ground the other hot side i would use a fuse tap and go into a circuit that gets power when the car is on.
you can pull a fuse and then hook a voltmeter on the open connections to see what kinda voltage and when its active to that circuit.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
db057
Aug 11, 2015 10:11 PM
