I just replaced my stock exhaust manifolds with headers and now I am getting "ERROR 34." I remember taking what looked like a ground wire off the rear manifold bolt on the passenger side of the 305 TPI motor. Could that be? The MAF is a very expensive item, could there be any other reason for the error?
Thanks,
Ben
Thanks,
Ben
@ZZKKER
close
- Join DateOct 2001
- Locationdecatur IL
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- Car86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
- Enginet\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
- Transmissionto many to list
- Axle/Gears9bolt 4:10 in the T/A
- Liked:0 Times in 0 Posts
you need to ratach that ground. that is the engine to body ground wire that compleats the ground circut.
good luck
thanks
anthony
good luck
thanks
anthony
thanks,
I will do that right away. It is a pure braided wire, I should have figured. It was on the charger when I tried to start it.....damn.....
Alright, now all the error codes are gone before startup but once I start the motor, the codes go crazy, is that also a product of a bad ground?
PS> who-ever said that for the computer to be reset, disconnect from battery AT LEAST 30 seconds, THANKS! I only did it for 5 and it never cleared the codes.
Thanks, Ben
Thanks, Ben
@ZZKKER
close
- Join DateOct 2001
Quote:
Originally posted by restoIROC
thanks,
Thanks, Ben
the books said to wait 15 min to 30 min "depending on the model", but i always just turned on the head lights after the battery is disconnected to drain the remaning current stored in the capacitors, then after waiting a min or 2 reatched and the codes are gone, but now i have a scan tool so i just clear them. Originally posted by restoIROC
thanks,
Thanks, Ben
yes a bad ground can cause false codes, spirattic running and glitches.
thanks
anthony
