Fog Lamp Troubles
Old Mar 3, 2003 | 01:01 PM
virginyan's Avatar
Car: 1990 Firebird
Fog Lamp Troubles
OK, I need some help form one of you electrical wizards please. My fog lights were not working....I pulled the bulbs, tested good. I pulled the dash switch...tested good. I checked the fuse....non existant. I grabbed a 15 amp fuse and went to insert it...kablooey...tried again...same result, blown fuse. I got my handy 12v testor out and found that the fuse socket was hot. Key was off, so I pulled out the switch, totally disconnecting it....fuse socket still hot. Just doesn't seem right to me. That fuse socket should not be constantly hot...should it? IF so...what do I do, disconnect battery and insert fuse? Any suggestions?
Old Mar 3, 2003 | 08:02 PM
406-Z's Avatar
Car: 87 IROC Z-28
Engine: 406-Mini Ram-AFR 195's-DFI Gen 6.32
Transmission: 700-R4 w/Art Carr converter
Axle/Gears: 9" - 31 spline - 3:89
Check your fog light relay. it is located on the left fender at the front where the fender bolts to the bumper cover and core support. There is a opening in the fender, that's where it should be. And yes the fuse socket (one side ) will be hot with the key off because you can turn the lights on with the key off. For the fuse to blow when inserted means there is a short. Pull your relay out and try inserting a fuse, if it blows use your VOM to test continuity between the fuse box and switch working your way down to the fog lights. If it does not blow replace the relay.
Old Mar 3, 2003 | 09:23 PM
MdFormula350's Avatar
the best pic i could find..
hope this will help some.
Old Mar 4, 2003 | 08:05 AM
virginyan's Avatar
Car: 1990 Firebird
Many Thanks
With this info you both have provided, it should be a problem much longer! Thanks alot. I will give this s hot Saturday and post the results.:hail:
Old Mar 5, 2003 | 09:54 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
that is the best pic that there is, it is strait out of the gm wireing diagram book.
that is what most of the diagrams i have to use look like.
thanks
anthony
1992Z28!
Nov 19, 2015 07:33 AM
mrbird
Oct 20, 2015 03:43 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Lmancha96
Sep 25, 2015 08:11 PM
